rangemaster 110 green
  • #69070
    suedehead1
    i am going to replace one of the simmerstats on the front of the control panel.
    Can anyone point me in the right direction as to how to get into
    this thing, I have never done one before and i cant
    see how to do it,
    Thans.
    #373606
    Jazzmeister
    Re: rangemaster 110 green
    dual fuel or gas or all electric?
    This info will help people to help you! 🙂
    #373607
    suedehead1
    Electric sorry I don’t normally look at these.
    #373608
    Jazzmeister
    Dependant on age…
    1. take off pan supports and look where they sit, you should see 4 crews around the outer edge of the spillage tray, remove these.
    2. Take off griddle plate/ wok support 2 screws under here.
    3. go around the rear remove 4 screws in total along the back that hold the spillage trays down.
    4.move the whole wok/griddle plate assembly to the right. ( you may have to give it a little encouragement.)
    5. lift off the left hand spillage tray.
    6.Remove the screws from the top of the control panel.
    7. Take off all knobs and timer buttons.
    8. Take off 3/4 scres on the underside of the control panel.
    9. pull off control panel and change required simmer stat.
    HOPE THAT HELPS…
    Jazz
    #373609
    suedehead1
    thanks very much i am going tommorrow to fix it,
    i dont think i could have done it without this info.
