Rangemaster 110. Tripping when heating up
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Rangemaster 110. Tripping when heating up
  • #69030
    OLLIE2806
    Hi guys,
    The above dual dual cooker (ser no. 5407 003596) is tripping the rcd 8 out of 10 times when heating to temp, the chap says when it does hit temperature it seems to stay on fine, the insulation seems ok the fan element & fan motor seem fine, there is no cooling fan that I can find, also there does not appear to be a cut out for the man fan element.
    Any ideas? Thanks
    #373483
    Criscold
    Re: Rangemaster 110. Tripping when heating up
    Are you checking the element when hot as I have had a couple where the fault disappears when cooling
    #373484
    cab
    did a Baumatic recently perfect when cold after 20 mins base element went to 1.2 meg
    #373485
    Jazzmeister
    Agree with the 2 above, do quite alot of R/M work and this would be the most logical explanation.
    Jazz
