RANGEMASTER 11O TOP
  • #82206
    alro
    Hi gents need to change timer anyone discribe how to take hob tops off to access control panel screws
    cheers alro
    #419136
    bazza500
    Re: RANGEMASTER 11O TOP
    Is it gas, ceramic, solid plate or induction?
    #419137
    alro
    its a gas hob top
    cheers alro
    #419138
    tinfish
    There are 3 or 4 screws under the control panel – remove them, then there are the same along the top. Pull off the knobs and the fascia comes off. Then remove all the screws holding the gas burners in place (3 in each) then you can lift the top up and prop it to give you access to everything. Reassembly is just the reverse, but it can be tricky lining all the burner screws up.
    Grant
    #419139
    alro
    sorry no screws in burners: 4 screws on top of hop top (right side)
    4 on left side this is a 5331 model with gridle and hot plate on left
    cheers alro
