Re above model,all electric range cooker the clock timer cannot be set, stuck on Auto. Is there a Bypass you can do on wiring to take timer / clock out of the loop thanks
Looking at the timer on connect it looks like it has 2 relays – one either side of the timer, if this is the case it would just be a matter of connecting the wires together from each relay ie relay 1 remove cables and join them together & then the same for relay 2.
