Rangemaster
  • #67144
    atech
    I’ve been to look at a rangemaster electric cooker today. As soon as you put the main’s cooker switch on, the main fan oven element comes on, and the neon lights up. The fan will only come on if you turn the main oven switch on. It comes on even when the timer is flashing ie not set. HELP
    #366473
    maltheviking
    Re: Rangemaster
    Stat/selector switch
    #366474
    Re: Rangemaster
    model?
    most likely the thermostat shorted? or, if the type where the stat pushes into the com swtich then it may have just popped off the back.
    #366475
    atech
    Re: Rangemaster
    Thanks Chaps. I was thinking stat or timer.
    #366476
    maltheviking
    Re: Rangemaster
