Re: rangemaster 8090 no power
I had a Smeg cooker with very similar symptoms this week. Turned out that there was a fault in the terminal block where the mains supply came in, so the Neutral was not connected to the cooker. This meant that all the neutral terminals I tested inside the cooker gave a live reading.
I’d suggest checking the supply right from the plug/mains outlet and follow it through the cooker to see if there are any broken, loose or corroded connectors.
That’s not to say that it couldn’t be anything else, but at least this is a place to start. Hope it helps.
Jon.
