Rangemaster 90 (6432 150165) Ceramic Hob
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Rangemaster 90 (6432 150165) Ceramic Hob
  • #91064
    jontymox
    Good evening,
    Wondering if anyone can assist with a problem on the above hob?
    Essentially, the hob/hob hot lamp remains lit permanently for the right hand hob.
    Evidently the customer heard a popping noise, accompanied by the hob tripping out.
    However, although the hob in question still works and can be controlled, the light remains lit permanently.
    There isn’t anything obviously burned/damaged, and I don’t have much experience on range ovens so wonder where I should be investigating further?
    jonty
    #446915
    Alanj
    Re: Rangemaster 90 (6432 150165) Ceramic Hob
    Hi Jonty, I would check the limiter on the hob/element. I had one recently that caused the same problem.
    Alan
    #446916
    jontymox
    Thank you Alan,
    Will do.
    jonty
