Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Rangemaster 90cm thermostat issue
- This topic has 6 replies, 2 voices, and was last updated 6 years, 4 months ago by
manwithaplan.
December 6, 2019 at 8:08 am #96840
manwithaplan
ParticipantHi, I’ve got an oven cleaning & repair company.
A customer of mine has a Rangemaster Kitchener 90cm (serial number 7998 005163). They thought that the thermostat in the main oven (bottom left) was working inconsistently.
I cleaned it & tested the thermostat afterwards, but the temperature was correct. They contacted me a few days later saying that again food wasn’t cooking properly.
I bought and fitted a new thermostat (genuine Rangemaster one) a week or so ago, but again they’re saying that food isn’t cooking properly. I went over and tested the thermostat again, it did hit 180 as requested, but when I turned it up to 220 it didn’t react and the temp started dropping.Is it likely that this new thermostat is faulty (or I’ve got an incorrect one)? Or could it be the selector switch (that the thermostat piggybacks on) that is faulty and that it isn’t allowing the spindle to turn sufficiently?
Many thanks in advance for your help.
Jack
December 6, 2019 at 10:49 am #464988electrofix
Moderatorthere is a thermal cutout next to the element at the rear
https://shop.ukwhitegoods.co.uk/p093026-rangemaster-oven-thermal-cut-out-thermostat
had a few of these go faulty
December 6, 2019 at 2:50 pm #464989manwithaplan
ParticipantMany thanks for the response Dave.
Regarding the thermal cutout; I thought a faulty one would prevent the oven working?
Can the oven still work, but inconsistently with a faulty one?Kind regards.
December 6, 2019 at 3:51 pm #464990electrofix
Moderatorit can be cutting off too soon
had one with similar problems to yours. got to a certain temp and cut off
cant remember but I think it only cuts off the element
December 6, 2019 at 4:27 pm #464991manwithaplan
ParticipantOk great, I’ll give it a go.
Many thanks.
December 6, 2019 at 4:31 pm #464992electrofix
Moderatorthink the indicator lamp stays on when it trip
so if the indicator lamp is on and its not getting hotter then most likely statbut can never be 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} without testing
December 6, 2019 at 5:20 pm #464993manwithaplan
ParticipantSure.
I’ll order a new stat, but will test the old one before replacing it.Kind regards.
