Re: Rangemaster change thermostat and switch.
remove 4 screws on hotplate (on top) remove 2 screws on the grill plate ( right hand side under griddle plate…remove 2 large screws rear of solid hotplate (about an inch uners hotplate top)…remove 2 screws in griddle plate rear ( actually go into the spillage tray)…slide griddle plate assy to the right…and move it back (may have to release earth wire)
hotplate will ift straight up and off. then access the bezel by removing all screws around it…( but not the timer screws) pull it off and bobs ya uncle!!
Jazz!!
Ps.. reverse of above to re-assemble!! 😆
