Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Rangemaster Classic 110 Fan oven stopped working
- This topic has 9 replies, 2 voices, and was last updated 2 years, 5 months ago by
The Equalizer.
October 29, 2023 at 6:10 pm #102341
The Equalizer
ParticipantHi All
It’s been one of those weeks, Tumble dryer broke for the last time, now replacing as it’s probably over 10 years old.
Just tested positive for covid.
Now, the oven..Its a Rangemaster Classic 110 induction.
Serial No. 8751 156126
The Fan oven gave a Burning rubber smell, a pop and a Poof of smoke.
Since then, the Fan won’t work.
The Oven seems to heat, but no Fan.
The Hobs seem fine as does the Non Fan oven.
Is it something worth tackling myself?Many Thanks
Simon
October 29, 2023 at 11:00 pm #488403electrofix
Moderatora lot depends on your level of skill on electrical fault finding
at best it the fan motor but could be other things
you could access the fan motor and see if its burnt or smells burnt
October 30, 2023 at 10:59 am #488404The Equalizer
ParticipantHi Dave
I didn’t expect your good self to reply.
My level of skill on fault finding is not too bad, no where near your level of course, I’m strictly a DIYer.
I’ll do some googling to see if I can find a video on that specific cooker and how to access the fan.
I don’t know whether its accessed from the back or front etc.I’ve had tumble dryers in pieces replacing belts and drum bushes etc as you now, but not messed much with cookers.
Simon
Simon
October 30, 2023 at 11:11 am #488405The Equalizer
ParticipantJust seen a very useful youtube clip on how to remove and replace the fan motor on a rangemaster fan oven.
That looks perfectly doable to me.
So I just need to locate the correct part. I’ll head to the UKWhitegoods shop see what they say
October 30, 2023 at 2:43 pm #488406electrofix
Moderatorshould be a fairly standard motor unit but did you check that was the problem , although it does seem likely ?
October 30, 2023 at 6:51 pm #488407The Equalizer
ParticipantOddly enough, my multimeter stopped working when I got it out
TypicalI did find a current detector that told me that I had voltage going up to the live of the Fan motor. I also saw a burnt area around part of the motor around the Winding. So I gambled £60, that it is the fan.
If it’s not, then I guess that’s on me, and I’ll have to get an expert in….. Once my Covid has gone.
I’ve just been googling Multimeters lol they range from £15 for the cheap n nasty to about £300 for the Fluke. sheesh.October 30, 2023 at 7:00 pm #488408electrofix
ModeratorI use UNI-T meters they work ok for what i need
you can get them used off ebay for not too much
November 1, 2023 at 11:33 am #488409The Equalizer
ParticipantJust looking now at the Uni-T meters Dave.
Thanks very much.
Simon
November 3, 2023 at 1:58 pm #488410The Equalizer
ParticipantGot the Fan today thanks Dave
I’ve fitted it, and it all seems to be working perfectly.
So thanks very much once again for your advice, I very much appreciated and needed it.
Regards
Simon
November 3, 2023 at 5:49 pm #488411electrofix
Moderatorno problem glad to help
