hi can anybody help had a call to yesterday to go see a rangemaster cooker. What would couse the nutral wire to burn on the conection point were cooker cable connects to the cooker. it has burnt so bad it nearly went alight i cant tell if it was a loose connection . just woundering if anybody had seen this before . ❓ FLASH
Did a nasty Menghetti range thing last week where the connector block was so badly burnt that it had carbonised into the live. Old house, wire fuses – big bang. I suspect that it was just poor connecting in the first place. If you want the connections tight, use a straight bladed screwdriver.
