Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › RangeMaster Double Oven R9044 tripped RCD
- This topic has 12 replies, 2 voices, and was last updated 4 years, 6 months ago by
JohnDIY.
October 5, 2021 at 9:50 pm #100103
JohnDIY
ParticipantHi, Any help to identify fault would be appreciated. Fish and chips were being cooked in the bottom oven when it tripped the RCD. I flipped the switches back and expected it to trip again but it didn’t. I check the oven and it was on. After 10mins I checked the fish and chips and the oven was warm but not hot. It looked like the element had stopped working. I let the oven cool and then started some checks. The top oven works fine. It heats and the cooling fan comes on straight away as soon as the knob is turned. With the bottom oven no cooling fan comes on when the knob is turned and it used to, but the oven does start to heat. The circulating fan at the rear does work. I wondered if the cooling fan for the main oven is the cause of the issue and has possiblly stopped working and caused the safety switch to kick in, or is now failing due to the result of something else. Many thanks
October 6, 2021 at 12:11 am #479234electrofix
Moderatorrcd trip are caused by elements 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time
October 6, 2021 at 8:06 am #479235JohnDIY
ParticipantHi Dave,
Thanks for the quick response.
So I grabbed by multi-meter this morning after watching a few youtube videos. I’ve removed the back of the oven and after removing the wire clips from each of the items and began testing.Everything came back with some resistance except for the fan element. I have removed it and an now looking for a replace.
Unfortunately the element I removed had ‘230v 1800w’ marked on it, but all the replacements for this model appear to be 2300w.
The manual states the max electrical load is 4.2kw. There are 4 elements in this double oven and I’m trying to do the maths to make sure the new replacement part at 2300w will not exceed the max load.
Top Oven Grill Element 1000w
Top Oven Base Element ?w (not sure)
Bottom Oven Fan Element 1800w removed (or 2300w replacement)
Bottom Oven Grill Element ?w (not sure)
I did buy this refurbished 4 years ago and wonder if the shop replaced the fan element but with an 1800w and not the 2300w?October 6, 2021 at 12:10 pm #479236electrofix
Moderatorwhat is the serial number of the unit so i can look it up ?
October 6, 2021 at 12:22 pm #479237JohnDIY
Participantserial number: 090625000001
Prod Code 8565
R9044 Contemporary 90cm s/steel bi ovenThanks
October 6, 2021 at 1:01 pm #479238electrofix
Moderatorhad problems with this
your serial comes up as incorrect
searching r9044 brings up poss serail as 8565
looking at that unit on rangemaster brings element
https://shop.ukwhitegoods.co.uk/12570030-fan-oven-element
cant promise i am correct without the correct serial
October 6, 2021 at 1:24 pm #479239JohnDIY
ParticipantThanks Dave. Is the 500w difference between the two going to cause any issue? Just thinking the oven has worked on the 1800w fan element for the last four years and I’m now going to put a 2300w replacement in.
October 6, 2021 at 1:46 pm #479240electrofix
Moderatordo you want to double check the serial as there may be more than one model with designation R9044
on rangemaster the first 4 digits give you the model no, so if thats wrong you get nothing or the wrong one
October 6, 2021 at 2:00 pm #479241JohnDIY
ParticipantI’m looking at the sticker on the left when you open the oven door.
Serial Nr: 09 06 25 000001
Type: E88A / C15524DTC
Prod Code: 8565
FCAAD5051003959
ATLAS D8 PP SV554TCI would provide pics, but there is no space left.
October 6, 2021 at 4:31 pm #479242electrofix
Moderatorwell the model is 8565
and with that rangemaster says part no is 12570030 2300 Watts
if you want to fit 1800 then
https://www.elementman.co.uk/rangemaster70032.html
this should fit just check sizes
October 7, 2021 at 7:51 am #479243JohnDIY
ParticipantThanks for all the info and help Dave.
I think I’m going to go with the 2300w element as I believe the refurb shop I got the oven from probably swapped out the original element with the 1800w I have removed. I also noticed the one I removed only has two loops instead of the three, but I’ll just get the new element and see how it goes.Once again thanks for your help!!!!
October 7, 2021 at 8:21 am #479244electrofix
Moderatorthe triple elements last longer as the watts per inch is lower due to the extra loop
also if you want reliability fit a quality element . That mean the genuine part or one made by Irca
October 7, 2021 at 10:11 am #479245JohnDIY
ParticipantThanks Dave. I just purchased the IRCA element. Thanks again!
