Rangemaster Leisure 110 Fan Oven Dial
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster Leisure 110 Fan Oven Dial
  • #100240
    Telcontar
    Hi folks,
    Recently the dial for the fan oven on my Rangemaster Leisure 110 went on the fritz – the dial has lost it stop, rotating through 360°, and the oven no longer turns on.
    Is this something I can repair myself and if so, what part do I need?
    TIA
    #479831
    you need to check whats broken first
    i would check the knob first
    Telcontar
    The knob seems fine. I can pull it off and turn the spindle all the way around.
    #479833
    right well we need to find out whats behind it
    will need the full serial no and which knob it is. i know its main oven but dont know where it is in the row of knobs
    also any repair from this point will probably mean you have to remove the whole top of the cooker so your skills will have to be able to do this
    Telcontar
    Serial no is 5407001125. It’s the middle dial of the three, for the fan oven. Do you know if there’s a service manual available that would show what needs doing?
    #479835
    https://shop.ukwhitegoods.co.uk/a026454-rangemaster-110-right-hand-oven-thermostat
    this is the control for the fan oven
    to fit this the whole top and back would have to come off to do this because the sensor tube goes at the back of the oven cavity
