Rangemaster. Oven element, or thermostat?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster. Oven element, or thermostat?
  • #86773
    GlenM
    We have a Rangemaster Professional 110 Ceramic hob electric oven which we bought secondhand 8 years ago but which had hardly been used.
    The left hand (non fan assisted) oven has never been brilliant and I have always put this down to it not being a fan oven. However, just lately it has got worse and never seems to get hot enough. Yesterday I put it on for about half an hour and it had only got to 140 degrees.
    Is the fault likely to be the element, or the thermostat? As element has two coils I am wondering if one could be dead.
    Thanks.
    #432984
    Re: Rangemaster. Oven element, or thermostat?
    It’ll be an element most probably but I think you may be looking at it the wrong way. There should be an upper element, almost always doubles as a grill element and a lower one you can’t see under the base.
    Either gone on a static oven can give what you describe.
    GlenM
    Thanks. The grill is separate and is above the left-hand oven. I can’t see a lower element, so, if there is one, it must be under the metal floor of the oven. Perhaps I should take the back off and see if there are any connectors visible there from a lower element.
    #432986
    There should be on there but, you won’t see it.
    GlenM
    Thanks. A job for the weekend. Are there resistance readings available for the elements?
    #432988
    Nope.
    Either it is open circuit or mot pretty much.
    GlenM
    Ok. I have read typically 20-30 ohms is good, so effectively open circuit.
    #432990
    Replacement then.
    If you get Dave on spares@ukwhitegoods.co.uk he’ll sort it out for you.
    GlenM
    Sorry, my last post should have read closed circuit.
    I have just tested the elements this evening and I got the following readings: –
    Bottom element – 52 ohms.
    Middle top element – 44 ohms.
    Outer top element – open circuit.
    New top element required.
