Re: Rangemaster oven not heating
Not had a chance to pull the oven out again yet but I’ll do it tonight. I presume I’m looking for a short circuit or low resistance?
Spoke to rangemaster technical department who advised that if the element has been replaced and the thermostat appears to be functioning correctly then the issue will be with the thermostat/selector switch which come as one unit.
Seems to be relatively straightforward to replace – control panel fascia off, disconnect wiring, LH side panel removed, unclip the probe and disconnect the thermostat and re-install in reverse order. That sound correct? Thanks.
