rangemaster oven not working
Home Forums Public Support Forums Help And Support Cooker And Oven Forum rangemaster oven not working
  • #12443
    jimcantfixit
    hi my rangemaster duel fuel is 4 years old every thing is working fine except for the fan assisted oven which has just stopped working but the fan still comes on, anyone no how to fix this prob
    #149716
    gegsy
    Re: rangemaster oven not working
    Probably circular element around the fan. Not too bad to chnage can be done from front with care, just the holes to allow the connections of element through tend to be on the small size and generally pull the spade connectors off.
    If this happens you will have to re connect by removing rear range locating wires and attaching to corrrect location on element.
    as always unplug before attempting any work on this appliance.
    Parts available from spares@ukwhitegoods.co.uk
    :plug:
    wsts
    gegsy wrote:Probably circular element around the fan. Not too bad to chnage can be done from front with care, just the holes to allow the connections of element through tend to be on the small size and generally pull the spade connectors off.
    :plug:
    cannot be done from front alone as the earth spade will not fit through the hole except on the latest models that would be under warranty anyway. Power off before removing any panel.
