rangemaster pro 90 dual fuel oven stat
Home Forums Public Support Forums Help And Support Cooker And Oven Forum rangemaster pro 90 dual fuel oven stat
  • #86939
    atanquerel
    Hi Guys,
    Just wondering if anybody can lead me in the right direction to get this oven apart to change the main oven thermostat?
    Many thanks in advance,
    Aaron.
    :l)
    #433453
    Re: rangemaster pro 90 dual fuel oven stat
    Try and avoid writing two separate threads on the same subject. What are the symptoms that make you think the thermostat is at fault?
    #433454
    atanquerel
    ok.
    oven element comes on but doesn’t cut out. no tell-tale click when you rotate the knob. chicken was cooked in 20 minutes 😉
    #433455
    OK, next question, being as it appears you do indeed need a new thermostat you will need to provide the FULL model number and serial number for the correct replacement.
    #433456
    atanquerel
    Cheers, it’s a:
    PROF PLUS 90 FSD DUAL FUEL ST/ST
    8434 157014
    Thanks,
    Aaron.
    #433457
    This is the one for you then….
    https://shop.ukwhitegoods.co.uk/p026819 … thermostat
    #433458
    atanquerel
    awesome, thanks. any ideas on how to get access to change it? I’ve looked about and can’t find any tips on where to tackle it.
    thanks again for the help so far
    #433459
    atanquerel
    any takers on helping me? thanks 🙂
