rangemaster professional 90 ceramic
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries rangemaster professional 90 ceramic
  • #58903
    suedehead1
    hi,
    the display on the cooker is not lighting up so you cant put the oven on.
    i called out late today and didnt really have time to rip it apart.
    am i right in assuming its the timer?
    #336062
    Re: rangemaster professional 90 ceramic
    Nope
    is all the other parts of the cooker working ?
    Common for the relay wire to heat up and just come off.
    Bryan
    #336063
    suedehead1
    the hob and grill elements are working,
    #336064
    blackandwhites
    Not sure,but I think there may be an inline toc in back panel.
    #336065
    suedehead1
    i had a look on connect and there isnt one listed but it might be worth checking although i will need a crowbar to get the cooker out of the space its in.
    #336066
    Jonah
    Check the terminal block, U clips may not be tightened correctly
    #336067
    Jazzmeister
    As Jonah said…but there is usually a direct feed from the terminal block to the timer….so if it isnt the terminal block it will more than likely be the timer!!
    P.s ask the customer for the instruction book….wiring diagram is in the back!
    Jazz!
    #336068
    suedehead1
    thanks for the info customer has no instruction book and the house has been built round about the cooker.
