Rangemaster professional plus 110 induction 13 yrs old range cooker
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Rangemaster professional plus 110 induction 13 yrs old range cooker
  • #101494
    JENKS
    Fault is E4 on the display panel and the top center hop does not work.
    I have swapped both master connection boards over and also swapped over two of the hobs but the same fault comes up.
    the only two other boards that may be at fault could be the induction driver pcb or the hotplate pcb module.
    which one is more lightly causing this fault.
    Paul
    #484969
    e4 seems to be a communication error
    could need configuring or and need new board
    you have to re configure after fitting new parts which is a sequence to follow on the control knobs
    should be able to find out how
    JENKS
    Hi Dave
    This is the earlier older version that has multiple boards and i dont believe that it need configuring.
    I have fitted the larger board to a rangemaster in the past and configured it but this one is different.
    It has the boards that i listed in my original enquirey thanks.
    Paul
    #484971
    Hollytree_Technical
    You don’t give a model/serial number so I can’t check for certain but I think that the following document may be what you need.
    http://www.hollytreetechnical.co.uk/images/UK_Whitegoods/Rangemaster_Induction/Basic{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20Induction{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}20Training.pdf
    Jem
