hi all need help with this one I have a range which is flashing e8 on four of the displays and on the fifth it has a symbol that looks like a u with a line under it.
first what dose e8 stand for and second, dose that symbol mean that that is the plate that has the problem.
dave a question first can the fans be replaced because I can`t find a part number for the fan only the module.And second we are talking about the fans in the main unit fvla057472
mikehha wrote:dave a question first can the fans be replaced because I can`t find a part number for the fan only the module.And second we are talking about the fans in the main unit fvla057472
probably the fans on the boards
like computers the fan will be monitored so things dont overheat. will try to scan the doc i have
you could check the fans to see if they seem tight or contaminated
thanks dave . what a ball ace of a job fans seem to run ok out of the module and there does not seem to be anything blocking or fouling the fans! will try another avenue because a module/induction unit is £1000.
