Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Rangemaster RDW459FI/SF tripping RCD. Heater element gone?
- This topic has 5 replies, 2 voices, and was last updated 6 years ago by
RANGEmasterG.
March 25, 2020 at 10:47 pm #97373
RANGEmasterG
ParticipantModel : RDW459FI/SF
(I think really its a Hotpoint unit as I have letter from Hotpoint sent to a previous owner re: fire risk, stating it might be a Hotpoint FDW20 / FDW60 / FDW65A, its a built in unit)On Monday evening my downstairs sockets tripped the RCD whilst the dishwasher was running. I reset the RCD and everything came back up ok, including the dishwasher.
On Tuesday evening the RCD tripped again, part way through the dishwashers cycle. I reset the RCD, but each time I attempted this the dishwasher would briefly resume before immediately tripping the RCD back off.
What I did next:
- Unplugged the dishwasher and reset the RCD. Everything else came back up ok.
- Filled a kettle and plugged that into the dishwasher socket. Kettle started boiling ok. So suspect socket is ok.
- Dismantled dishwasher plug to check the fuse. Fuse has continuity.
- Plugged the dishwasher back in and ran a cold water cycle. Cycle completed ok. Suspect plug is ok, but suspect water heater element has gone. This ties up with the state the dishwasher was in when it first tripped. The cold pre-rinse had completed, and the tablet had been dispensed.
So at this point I am expecting that the water heater has gone. Got the dishwasher pulled out, water and power disconnected. Opened up the bottom of it and removed the heater element. I did see some water on one of the heater terminals, but I put this down to droplets running down from when I was disconnecting one of the water pipes into the heater. I measure 28 Ohms across the heater terminals. Which makes me think it might actually be ok? I was expecting to see no continuity. One of the terminals to the wire which runs across the heater has some green corrosion to it and a rusty mark/stain on the plastic connector body.
I have tried searching specifically for a heater for the Rangemaster model number, with varying success and prices ranging from £13 to £53! It seems like a very common design that goes in pretty much every dishwasher with a 1800W flow through heater.
So, I have some questions:
- Is the heater element the likely cause of the RCD tripping?
- Is the fault internal to the heat element? Or is it to do with a fault in how its connected into the machine?
- Is the 28 Ohm reading “normal” for a 1800W flow through heater?
- If I can’t get hold of a “Rangemaster RDW459FI/SF” specific heater is it ok to use a generic one from e-spares say? Like this : https://www.espares.co.uk/product/es1250400
Appreciate any help anyone can offer.
Thanks,
GeorgeMarch 25, 2020 at 11:15 pm #467379electrofix
Moderatorfast way
run dishwasher till it tripremove plug from socket, disconnect heater, plug back in and reset trip
it should continue where it left off and if no trip you found it
not made by hotpoint. all indications are its a cheap import
I would contact the site shop as the heater seems steep at £42 and since Espares hide the numbers to stop you getting a better dealgeneric heaters are normally ok
March 25, 2020 at 11:31 pm #467380RANGEmasterG
ParticipantThanks for the response Dave, would doing that give a different result to the cold water cycle I ran?
March 25, 2020 at 11:37 pm #467381electrofix
Moderatordid it trip on the cold cycle
March 25, 2020 at 11:46 pm #467382RANGEmasterG
ParticipantNo it completed the cold cycle fine, drained as normal etc.
March 25, 2020 at 11:55 pm #467383electrofix
Moderatorthen its very likely the heater then
