Rangemaster RDW6012FI Dishwasher Lower Spray Arm No Water
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Rangemaster RDW6012FI Dishwasher Lower Spray Arm No Water
  • #76398
    oakleyjo
    I am looking at a Rangemaster RDW6012FI Dishwasher. The top spray arm is turning ok, but the bottom one isn’t turning at all. The arm itself is completely unblocked. Any clues appreciated. I can see that the main wash pump assembly has a water valve on the side, does this control flow to the lower arm? if so is this the most likely culprit or is it more likely to be the PCB? Can you get just this valve or is it only available with a replacement wash pump?
    Thanks,
    Jon
    #398258
    Re: Rangemaster RDW6012FI Dishwasher Lower Spray Arm No Wate
    you are prob on right track. you will find the dishwasher has a half load facility.
    if customer does not use it strip valve and remove the plastic flap
