rangemaster RDW6012FI/SF E6
  • #89343
    char14lew
    I’m having trouble clearing the E6 fault code on this dishwasher.It had a flooded base due to lower spray arm hub working loose.All dried out,Checked float switch,working ok and no corrosion on terminals.
    Tried the usual cancel button- shows 00 then E6 straight away after and drains out.
    Anyone experienced this?
    thanks in advance
    Darrell
    #441092
    char14lew
    Re: rangemaster RDW6012FI/SF E6
    There must still have been moisture on a connection as I went back a week later when it had fully dried out and the E6 fault code had cleared and machine was working again!
