Rangemaster sparking problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster sparking problem
  • #89362
    sazgaz
    i have a rangemaster oven with double gas ovens. I have replaced the spark generator as neither oven would light. Both ovens now light however the spark generator clicks constantly on the left hand oven. I’ve triple checked the circuits and can find nothing wrong.
    #441150
    Lawrence
    Re: Rangemaster sparking problem
    It will need the FSD which is not a DIY job as its a gas carrying part ,you need to find a gas safe registered repairer.
    #441151
    sazgaz
    If i turn the power off there is no gas coming through so I would have thought that the FSD was working?
    #441152
    wsts
    The FSD has nothing to do with the spark generator, I know what the fault is but unfortunately dont give out gas appliance repair information, the spark generator comes under components that require you must be “competent in gas work” or “gas safe registered” to be able to work on.
