RANGEMASTER TIMER – 13849-072
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts RANGEMASTER TIMER – 13849-072
  • #62794
    gadgetdad
    Hi guys, can anyone point me at a replacement timer for a 110DF (GREEN), approx 10 years old – above number is the Diehl number on the side of the original.
    I have got the recommended replacement from Connect but it trips the RCD in the house as soon as it is connected !! assuming I have connected it correctly. Trips with just the live/neutral connected – not marked up so tried them other way round – still trips !!
    gadget
    #351336
    washtronics
    Re: RANGEMASTER TIMER – 13849-072
    are you sure you have connected live and neutral correctly-not to the relay?
    #351337
    gadgetdad
    Its a twin relay timer –
    http://www.espares.co.uk/part/cookers-and-hobs/leisure/p/1092/433/0/0/1331532/cooker-timer.html
    as above – have connected the live/neutral to the bottom two inputs – the 4 relay outputs are to the left of the picture.
    #351338
    jeremy
    if you call RM technical they will tell you exactly which wire goes where for sure. as its a DF they are very obliging for any technical info i hv found in the past!
    r u sure its just when u connect the timer that it blows the rcd and there isnt something else going on ?
    #351339
    gadgetdad
    Yep definetly, soon as i power it at the wall with the new clock in it blows – put the old clock in, which works except the lcds are blown in places so can be read – its
    fine !!
