Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Rangemaster ToledoXT 110 (d/f)
- This topic has 10 replies, 4 voices, and was last updated 16 years, 9 months ago by
clivejameson.
June 25, 2009 at 5:19 pm #46626
clivejameson
ParticipantThis is a dual fuel range that blew the trip….on inspection a component had blown and dropped into the main oven selector switch. The question is what the heck is the component? It piggybacks with wires onto the warming plate ‘hot’ neon at the right hand end but there’s almost nothing left of it to identify save for a small blob of metal on the end of each wire!
Any ideas?June 25, 2009 at 7:26 pm #290238funkyboogy
ParticipantRe: Rangemaster ToledoXT 110 (d/f)
think you need to order new warming plate on this..
dont know what it is , but comes with warming plate assy..ally
June 25, 2009 at 8:58 pm #290239clivejameson
Well the neon certainly appears to be part of the hob but that has two wires to supply it and the component that ‘let go’ piggybacks onto the harness at the neon terminals so if anything it might come with the harness but the parts diagram doesn’t seem to show anything.
Just had a thought….if anyone has a wiring or connection diagram i could follow the circuit to find out what it was?
June 25, 2009 at 9:48 pm #290240Jazzmeister
common problem with these lately…supposedly due to lead free solder that they now have to use due to EU regulations…the solder just does not stick as it should, wires drop off fall wherever and go bang!
Order a new warming plate and all will be well!June 25, 2009 at 10:06 pm #290241clivejameson
What actually is the component that went bang….i’m really intrigued!
June 30, 2009 at 10:11 pm #290242Jazzmeister
Two wires go from the warming plate neon to the warming plate (element) where they are attached by solder…when the solder comes off the wires drop down earth out and go bang! does this answer your question?
Jazz
July 1, 2009 at 8:12 am #290243clivejameson
Ahhhh that explains it! Do you have a part number for that element please? (the diagrams are far from clear!)
July 1, 2009 at 3:30 pm #290244clivejameson
Or is the element integral to the ceramic top/hob?
July 1, 2009 at 6:13 pm #290245Jazzmeister
Acomplete new warming plate is required.Sorry i dont have the part number…but call rangemaster they will give it to you!
Jazz
July 2, 2009 at 9:10 am #290246ANDYVIVO
Hi Clive
What is the 10 digit serial number?
Regards AndyJuly 2, 2009 at 6:26 pm #290247clivejameson
I didn’t get the serial pftttt….we’ll order from the diagram and see what arrives 😉
