Rangemaster wok burner problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rangemaster wok burner problem
  • #98091
    Jongas
    Hi, maybe someone has a suggestion or has come across this before
    I recently changed the flame spreaders and burner caps on this LPG cooker because the old ones were distorted. I am getting flame lightback on both of the wok burners where the spreader meets the base on the external ring feed
    I have replaced the injectors with new ones 53 internal and 82 external , regulator is giving a steady 37mb but still the same problem, I would appreciate any advice
    #470859
    kaibart
    Well only thing I would to is change the wok base that the injectors go into as that’s all thats left
    #470860
    Jongas
    Thanks for the advice kaibart, I think you are right, not much else left…. The bases may have got distorted internally even though they look OK. I’ll let you know what the outcome is…….. A lot of dismantling ahead!
    #470861
    kaibart
    I done one yesterday hopefully all the screws come out
