RCD/ cut out / hotpoint WM
Home Forums Public Support Forums Help And Support Washing Machine Help Forum RCD/ cut out / hotpoint WM
  • #78035
    paulmnow
    Hello
    up to two days ago my washing machine was working great.
    Then the RCD on main fuse board cut out when I tried to use the machine. I tried different plug sockets (with extension) but the RCD still tripped. All other sockets are ok with other appliances. Have I developed a short circuit of some type ?, or has an earth failed ?. Can i fix it and can I test relevant area with multimeter to isolate the fault.
    I`m assuming this type of fault is well known, but i dont know how to fix it.
    Many thanks
    PMN
    #404253
    Andy jones
    Re: RCD/ cut out / hotpoint WM
    You will need it tested with an insulation tester, not something you could do yourself unless you have the equipment and the know how
    #404254
    And a model number would also help. 😉
    #404255
    paulmnow
    Its a hotpoint aquarius 1200
    if that helps out then ok/
    I have suspected its a loose on coroded wire, but would like to know how to get to it
    #404256
    paulmnow wrote:Its a hotpoint aquarius 1200
    That’s the series and the spin speed NOT the model number. Look for it on the fascia panel or inside the door (Begins 9??? Or W????)
    #404257
    paulmnow
    hello
    model number is WM64, hope that helps
    thanks
    #404258
    That suggests a very limited knowledge of the subject.
    As already mentioned all components need checking with a a suitable megger or multimeter for insulation faults. A visual examination of all the wiring would follow if no component faults are found. The main motor and the heater would be the first things to test.
