Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › re bearings on an Indesit WD 12 S UK
- This topic has 8 replies, 7 voices, and was last updated 16 years, 9 months ago by
ashfordkent.
June 19, 2009 at 11:41 pm #46497
ashfordkent
ParticipantHi All
How do you go about doing a bearing change on an Indesit WD 12 S UK With the Metal Drum and rear Carrier. Never done one before. What do you have to remove, and what do you have to replace. Presumably spider only pushes through seal does it have to be changed ? Cheers for any advise
June 19, 2009 at 11:46 pm #289773Penguin45
ParticipantRe: re bearings on an Indesit WD 12 S UK
Pulley bolt and 8 bolts for the crosspiece off, give the shaft a thump and it should come out backwards. If the shaft is damaged, you’re looking at a tank replacement. Be careful – the tank itself is made of Bacofoil.
June 19, 2009 at 11:51 pm #289774ashfordkent
Thanks Chris typical Indesit sh#?
June 19, 2009 at 11:56 pm #289775Penguin45
None but the best……… :rolls:
Oh, pulley bolt can be an absolute s@d to break free – give it a right good belt first!
:p45:
June 20, 2009 at 9:26 am #289776helo_75
Participantyoull need to take the condenser and heate rbox as well, since its a wd12
June 20, 2009 at 12:58 pm #289777bzz67
heat up pulley bolt with blow torch to soften thread lock.
June 21, 2009 at 8:38 pm #289778evo1
wack with copper mallet will loosen threadlock ❗
June 22, 2009 at 10:46 pm #289779bigkid
Quick Tip…. Remove soap draw and belt then lay machine on its back with door open, preferably outside, fill with a good quality compost and plant 3 geraniums and a some trailing lobelia in the drum.
For added effect the filter housing will take a small Bergonia bulb and the soap box will look stunning with Bacopia trailing from it.
Dont forget to set machine on a rinse cycle every other day.
I have found during the winter that the machine covered with a polythene tent and the dryer switched to low temp, out of season tomatoes can be sucessfully grown. An Italian variety such as Merlonias Indish*tias seems to do well ………
A Titchmarsh.
:rolls:June 23, 2009 at 11:12 am #289780loopey
1st thing to check is to see iff inner drum has not rubbed away the outer
drum , have a look just above the heater is were it goes .. got caught out on this one this last week . spent half an hour putting bearings in and finding outer tub gone 🙁phil
