re BEKO frost free CDA653FS Defrost Timer Fault ?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries re BEKO frost free CDA653FS Defrost Timer Fault ?
  • #38062
    ashfordkent
    Hi All. re a Beko Frost Free CDA653FS called out as totally defrosted light still on Fridge stat ok. Clicked the Defrost Timer a click, f/f came back into life, cooling ok. Freezer heaters (evap and drip tray resitance check ok ) Fan working ok. Thinking Timer stuck in Defrost ? Cheers
    #257581
    BobHope
    Re: re BEKO frost free CDA653FS Defrost Timer Fault ?
    Hi ashfordkent,
    very common problem with all of the Beko defrost timers, you best change it or you will be recalled back soon.
    Bob.
    #257582
    smartin
    could also be the bi-metal on evaporator stopping timer from coming out of defrost part no 4252810185
    smartin
    #257583
    ashfordkent
    Cheers Bob + Martin. do you mean the dual fan / cut out stat fitted top on evaporator assy thanks
