re Belling Format 636 Electric Hob
Home Forums Public Support Forums Help And Support Cooker And Oven Forum re Belling Format 636 Electric Hob
  • #40648
    fostexboy49
    Hi anyone help got a Belling Format 636 ( 4841-00083-3 ) Stand Alone Cooker. Hob Rear Left 1.5kw fastlight Element only works flat out even on lowest setting. Front Right Large Halogen Only works flat out as well inner part of element not coming on at all. Any help Cheers
    #267117
    helo_75
    theres a good chance the regulator is faulty on both of them… the inner ring only comes on on lower settings generally
    i take it the rear one is just a single one?
    #267118
    fostexboy49
    Re: re Belling Format 636 Electric Hob
    Cheers for that I was suspecting regulators as if elements blown they would not come on at all. Yeah the rear one is a single element glows all over but flat out and called a Fastlight probably its a standard element. the front right is a Halogen, outside glows fine but flat out inner section not coming on at all. Would you know if the front Halogen regulator is a duel Regulator
    #267119
    helo_75
    dual regulators turn both ways
    if theyre all the same, then no
