re Bosch WM showing F04
  • #48866
    ashfordkent
    Hi all. Go a Bosch WM Model WFX2868GB/26 Customer says Intermitenly was getting to rinse on display and coming up as F04. Of course i sat through prog nothing. Now saying doing it all the time anyone got any suggestions she also said had FEE Help !!!!!
    #297994
    washermanuk
    Re: re Bosch WM showing F04
    Hi matey i had same fault code turned out to be drain pump intermittently
    not starting was worn out and jamming! it could be that?
    hope it solves your problem Brian
    #297995
    nomadPaul
    Certainly sounds like a slow drain prob – F04 is ‘not draining ‘ with a 6 minute cut off time. If it started happening on the rinse cycle then that would suggest a slow drain but if its now showing up every time then i’d guess either the drain pump is blocked/faulty or the drain hose/container is all clogged
