Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › re Candy CPCA270FFK fridge overfreezing
- This topic has 9 replies, 7 voices, and was last updated 17 years, 9 months ago by
ashfordkent.
July 5, 2008 at 10:34 pm #37906
ashfordkent
ParticipantHi all anyone come across Candy fridge/freezer CPCA270FFK fridge Side overfreezing water in bottle freezing solid running around -8 deg. Wet wall type. Module control how do you get to the Fridge Sensor / Thermistor if its that. Seems its put into cabinet then insulation added, sensor must dive down inside cabinet and attach to Fridge Evaporator somewhere at back but no obvious way to get out or replace. Any help Cheers
July 5, 2008 at 11:10 pm #257037Penguin45
ParticipantRe: re Candy CPCA270FFK fridge overfreezing
You have mail. You won’t like it very much……….. 😀
July 5, 2008 at 11:35 pm #257038ashfordkent
Cheers Chris. See what you mean Crap Design they obviously didnt expect it to fail the fools! Probably customer wont want (hopefully) a chunk of Insulation Removed and repaired with a load of tape to cover finish. post the outcome Peter.
July 6, 2008 at 9:21 am #257039Simon46
not the module?
S.
July 6, 2008 at 2:31 pm #257040helo_75
Participantyou can test the thermistor at the board end
aint had that many failing
July 6, 2008 at 9:38 pm #257041ashfordkent
Do you know What resistance you get at module end of thermistor and do you think it may be the Control PCB. Checked freezer section no build up of ice around Evaporator. Freezer section ok Just Fridge side Freezing everthig solid
July 6, 2008 at 10:51 pm #257042Penguin45
More stuff in your inbox…..
July 9, 2008 at 10:41 pm #257043lerch
Think this is the model hoover had problems with and were doing a recall on. The sensor is de-attaching itself from evap, if so unit is scrap really unless you wish to messing around re-foaming. 😀
September 25, 2008 at 10:46 am #257044DDSDDS
any chance i could have those emails too? as i have the same problem
September 25, 2008 at 11:08 am #257045subs
Ive done quite a few of these recently. Replacing the sensor and refoaming. Its not as bad as it seems (about half an hour- 45 mins max). Had no problems. On a few occasions it has been the board. When its been the board there has been signs like the light dont work even when you replace the bulb, or the fridge wont turn off at the control, or the fast freeze light wont come on/ go off. I find them to be a good little earner. When i tell the customer that the sensor is foamed in because the fridge is badly designed, and it could be a right off except for the fact that i can work out where the old sensor is, cut it out and replace it, saving the fridge, they are very happy. (It makes me look clever too).
Subs
