re Creda 48339 halogen removing unit
Home Forums Public Support Forums Help And Support Cooker And Oven Forum re Creda 48339 halogen removing unit
  • #42343
    fostexboy49
    Hi all, How do you remove top element assy on an Creda Electric Cooker, Stand Alone. Model 48339. Found couple of screws at back when remoed lid lifts a bit but obviously fixed elsewhere. Removed 3 screws (where the grill lid opens) from under dial assy but controls fixed solid. Plastic L shaped side trim solid bits of plastic wont pull off. Reason for removal need to check front right Halogen as not working. Hear the sound of the regulator when turned on but just not working. Any help in removal cheers. ps happy new year to all, hopefully.
    #273176
    aqualectric
    Re: re Creda 48339 halogen removing unit
    Take both of the sides off. There are screws along the bottom edge of the hob unit; one either side at the front and one per side at the back. The middle 4 screws each side hold the plate support brackets……don’t remove these until the hob is off and placed on a table. Turn it over (ie. glass side down on a towel to avoid damage). Then you can dismantle the plates with ease and security.
    BTW, the hob unplugs from a multi connector on the left of the hob.
    Power off before any work starts…. :plug:
    HTH,
    Steve.
    #273177
    fostexboy49
    Thanks for that Steve. Do the side panels pull out of the L Shaped End Caps easy ? Do You have to remove all thr screws down the front edges side trims ?
    #273178
    aqualectric
    Three screws down the back edge and three on the front edge of each side panel. (open the oven doors to access the front screws). Then gently ease the sides off from the back of the machine with a screwdriver starting at the bottom. Caution: the panels fall off suddenly – they are sharp and heavy. I always rest my knee at the side so I catch the panel as it comes free.
    Refitting is by pushing the side panel up under the refitted hob and pushing it in at the bottom. Fiddly, but not difficult. 😉
    HTH,
    Steve.
    #273179
    fostexboy49
    Tanks Steve A great help will give it a go. Happy new year to you
