Re Hoover HNC175-80 DRY SQUEAL
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Re Hoover HNC175-80 DRY SQUEAL
  • #43486
    fostexboy49
    Hi got a Hoover HNC175-80 Condenser Dryer with a dry squeel noise, gets worse when warmed up. Its Probably the 2 Drum Wheels at the front. Allready greased rear bearing. Can Anything else cause this, ie do they have seperate Jockey Pulleys for the Belt ? What parts needed to rectify ? how do you get at parts to replace ? Anyone got a parts Diagram ? Many Thanks
    #277394
    Re: Re Hoover HNC175-80 DRY SQUEEL
    Moved to Trade Tech. Please use this forum for your enquiries, especially if you need technical info.
    There is a file in your inbox.
