RE Hotpoint WT960G Parts
  • #43764
    ashfordkent
    Hi all, Anyone got Parts diagram for Hotpoint WT960G
    Need to get inside door Rim, Door Latch in wrong position ie pointing to the right as seen from front, obviously something inside broken. What parts would be required ? how do you get Handle past or through the rim ? is it a push fit ? thanks
    #278489
    Re: RE Hotpoint WT960G Parts
    Easiest way is to remove the door complete with the hinges and then split it.
    Not difficult to reassemble, might be worth opening it up first as the pin doesn’t actually slot into any holes, it rests against the front trim and may have just come adrift. Spring and handle often break on these as well.
    Handle is C00202588
    Front trim is C00202939.
    Rear trim is C00195806.
    Spring is C00112588.
    ashfordkent
    Cheers Jim. Still looking for a Parts Diagram if anyone’s got one
    #278491
    There have been no hard copy parts diagrams for years. The service manuals do not contain any parts information.
    Diagrams are to be found on the Partfinder CD rom or on Servicenet if you are an authorised agent.
