Re: re Ignis Dishwasher ADL348 Wash Motor
Check if its got the water sensor (flow switch) in the sump. Its a black grill on the right hand side of the sump. If it has they often clog with gunge and the flow of water wont activate the microswitch, hence shuts down pretty much when you state.
You can access this from the base with the plinth off, if your really lucky and ive been several times you can flush it out with some hot water and a syringe without removing it. (always worth a go).
Its a bit like the blocked sump hose on the Bosch easy to miss but dead simple when you know its there. 😆
