Hi all,
Indesit IS70C UK tripped electrics, found heater shorting water in housing. Checked pump seems to pump up ok. Checked for blockage in the hole from rear of condenser to pump seemed ok. Dryed out heater tried with damp towels still tripped, water back in Heater box, disconected heater runs ok. any thoughts thanks.
Join the club, I’ve got one doing the same. Removed the front of the condensor to make sure I had got it clean, dried out heater and cleaned drain channel. Still tripped so changed pump. Lasted two weeks and then started tripping again.
Changed heating element just over a week ago, fingers now well and truly crossed. 😥
