re Miele G675C
  • #37219
    ashfordkent
    Hi all anyone know the fix on Miele d/w model G675C leaking from air vent located top left in console housing (bit like the old creda slimline built under diashwasher vents) Only given info over the phone so no other numbers given to me Cheers
    #253919
    Re: re Miele G675C
    Take the door panel off, you will see a drain pipe from the fan behind the vent to the soap dispenser. This will be blocked. You might also want to check the shutters on the fan motor are closing as if sticking open it lets all the gungey water into the fan which will block the hose again.
    #253920
    ashfordkent
    Re: re Miele G675C
    Thanks Mark will try that. Only told over the phone problem so that will be a great help Peter
