Hi all. Anyone had a Permanent live feed to a Neff Integrated Dishwasher Heater box motor fitted on the bottom of the heater. Motor runs (and now very noisy) even if you cancel programme and it goes to the end and pump stops ect. The Model is S5444XIGB/16 Its one fitted with the overflow Float inside the Tub. Tested with Volmeter motor still getting supply 240v even when completly stopped, only shuts off if you open door or switch power off. Cheers
