Re Noisy Wash Pump/Motor Neff Integrated
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Re Noisy Wash Pump/Motor Neff Integrated
  • #43262
    ashfordkent
    Hi all got a Neff Integrated dishwasher Model S5444X1GB/16 Noisy Wash Pump/Motor still working just about. What parts would I get away with to fix ie just the Wash Pump and Sealing kit. Nightmare to get out built in solid so Cust having to get kitchen fitter in to get surround removed wont budge. So wanting to go Back armed Hopefully with Correct Parts. Was going to order from Neff parts 419027 sealing kit and part 481563 pump housing any suggestions thanks
    #276660
    Re: Re Noisy Wash Pump/Motor Neff Integrated
    If its the motor bearing shot then you will need more than just the sealing kit. TBH you wont know the full extent until it is removed. Unlikely to be just the seal.
    #276661
    The noise will be a rusty 608ZZ bearing so go armed with that too and an extractor and can of WD40. Together with a new Impellor kit and you’re all set to give it a go! 😀
    #276662
    boselecta
    I have found most of the time if its got to the stage that the bearings have gone then an entire motor will be required as the motor housing wil be corroded through.
    Fingers crossed if your doing a large job like this with just the bearings, seal and housing then!.
    #276663
    ashfordkent
    Yeah Cheers for that, Thinking Complete Motor. Anyone know part number for complete Motor/Pump Housing
    #276664
    ashfordkent wrote:Yeah Cheers for that, Thinking Complete Motor. Anyone know part number for complete Motor/Pump Housing
    Make a note of this link : –
    https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/indexs.htm
    #276665
    Dansta
    Dont forget the jubalee clip,the 1 on there is one shot.
