Re pipe clips
Home Forums General Trade Forum Re pipe clips
  • #71559
    larry
    I was wondering if other people have the same problem as i do when trying to retighten those horrible clips on whirlpool dishwashers the ones you have to try and crimp closed. Does any one know where to get hold of something better for the job or the proper tool for these clips, there must be one. Jubilee clips are no good because of the lump where the screw is fixed Larry.
    #381496
    Jazzmeister
    Re: Re pipe clips
    here is what I use :-
    http://www.ebay.co.uk/itm/Hose-Clip-Pli … 2566f50c40
    Jazz
    #381497
    larry
    Re: Re pipe clips
    Thanks for that info just been on ebay and ordered a set great stuff cheers Larry.
    #381498
    johnnyj
    Re: Re pipe clips
    I use these 5031687916532 and 5045174174251 from connect i know a bit pricy but i make enough of the job to cover the cost and i know it aint going to come back and bite me.
    #381499
    Re: Re pipe clips
    Qualtex now do thin jubilee type clips that actually work like proper ones and not the silly ones that are a faff to refit.
    robbo1973
    Re: Re pipe clips
    I use the thin type of jubilee clips from a local hardware shop the same as on connect and they are about £1 each
    #381501
    deltra
    Re: Re pipe clips
    8mm ones from westfield fasteners
