re Stoves cooker 61EDO
Viewing 1 post (of 1 total)
  • #49862
    ashfordkent
    Hi all, re Stoves cooker 61EDO model 444445542 s/n 50233936
    Both largest hob elements ( LH Rear, RH Front Both 1655watt ) come on flat out even on number 1 setting. Is it the Regulators? Also the grill in top oven does not work, but works ok when set on oven, is this the Grill/Top Oven Regulator? Thanks
