Hi , I’m having trouble reparing a Zanussi ZWX1506 w,machine . It takes in water then just sits there , apparently it’s had new brushes and main PCB but still the same problem . It spins AOK while pumping etc. but will not go through the wash cycle . I’m looking for some guidance as to where to look as I don’t have a wiring diagram so am not sure as to which pins on the motor do what , although the motor appears ok because it spins . To recap , starts wash prog , takes in water and then nothing at all , not even a twitch of motor movement .???? Any help would be hugely appreciated ,
Thanks in advance,
Best regards Phil
