Reading on triac
  • #97885
    kaibart
    Hi wondering if someone can give me some advice on what reading should get on the motor triac where the red arrow is pointing as I have error 9 on pcb which is motor triac this is a new pcb that I haven’t used for years:rolleyes: tia kai
    #469998
    kaibart
    Here’s the picture
    #469999
    traic has 2 legs you can get a reading from the 2 out side ones but you should get nothing between the middle on and either of the other 2. measure both ways as it can go half wave
    also it may not be the board. went to one house with a Zanussi with motro triac error ended up the motor was covered in condensation and the slight earth current upset the board
    kaibart
    I have resistance on the outer 2 that’s what makes me think it isn’t the main board this is one off a dc machine with the rectified at the bottom the old pcb had motor action just wasn’t completeling cycle must be duff pcb then:rolleyes:
    #470001
    still maybe a leaky traic so may be worth swopping it out
    dont recognise board what is it off ?
    kaibart
    Hoover nextra the traics normally blow to bits if a component is faulty think the machine is ber 14 years old and I’m no good with a soldering iron lol
    #470003
    Traics can go short between the 2 main terminals and also have leakage so you put a multimeter across them and you get a high resistance reading
    soldering traics is easy. the improtant thing is to get the correct tools
    A resonable iron no more than 25 watts
    desolder braid which suck up old solder
    flux which can help the solder flow when being taken off
    and solder to resolder it
    give it some protice its worth it as have resurected many a board. have just replaced an 16 leg driver chip on a hotpont dishwasher board. will find out if it works when i put it back. if it work its extra charge, if it fails then its scrap as unless you can programme it and i cant
