rear bearing shaft/spindle, for a CREDA 37449001SL
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts rear bearing shaft/spindle, for a CREDA 37449001SL
  • #16399
    TELL
    can anyone tell me if you can get seperatly the drum bearing spindle/shaft, and rivets. that slots through the rear bearing support. its parted company from the the rear of the drum itself.
    part no’s, and availabilty please if anybody can help. the drum is priced out of the market, @ £183 + vat!!!!!!.
    TELL..
    #169698
    Re: rear bearing shaft/spindle, for a CREDA 37449001SL
    the last time I had one of these, I drilled out the old rivets and fitted new ones. the same machine is still going strong, five years later. You could try the later shaft kit with the torx screws but you may have to drill holes in the drum to accomodate the screws.
    #169699
    TELL
    iadom,
    its not the rivets that have broken, although they will have to be drilled out, and replaceced. its actualy the whole centre bearing bush that i require, that rivets onto the drum. still need part no’s, and availabilty. also where to get one?. thanks.
    TELL..
    #169700
    Dave_Conway
    Drum shaft repair kit part number 1701662 but it’s for the later drums, as Iadom says, you may have to “modify” to fit 😉
    #169701
    There is a shaft repair kit that includes screws and a new bearing, part is a 1701662, around £8.50 + vat list price. Not sure if it will fit but I am sure it could be modified. 😉
    :wave:
    #169702
    Dave_Conway
    :wave:
    #169703
    TELL
    thanks dave, that should do the job.
    TELL..
