Recommendations to replace ageing Diplomat adp3101 oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Recommendations to replace ageing Diplomat adp3101 oven
  • #57912
    gmacp
    Hi all, after replacing the the element and fan in last 2 years on my Mum’s oven, the fan is on the blink again and she would like a replacement. My problem is that I want to try and make this a single trip over to see her and fit new oven and I/she can’t find the manual with dimensions in for her ageing diplomat (probably me that lost it when previously working on it). As mum not capable of pulling oven out and measuring space available, does anyone know/have access to dimesions (I’ve googled everywhere to know avail). Either that if soemone else has swapped this model for new oven that fitted no problem and they would recommend that model, please let me know.
    Many thanks
    #332652
    don
    Re: Recommendations to replace ageing Diplomat adp3101 oven
    The instruction manual can still be obtained from hygena Diplomat spares and it`s not too expensive either.
    If the worktop is 60cm deep then any single oven will fit, Indesit group tend to be 569mm to front of door, Bosch Neff group 571mm.
    The only time there may be a problem is if a gas hob is fitted directly above and the pipework is protruding too far forward.
    HTH 🙂
    Don
    #332653
    gmacp
    Thanks for quick reply ❗
    I never found that site in all my searches and at least I have a source for the info I need now. However as they want over £10 including delivery I think we’ll be having another good look at both houses before we order, but at least I have a solution, thanks 😀
