Reconditoning a 50’s fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Reconditoning a 50’s fridge
  • #8992
    I’m trying to find out how I can recondition a 1950s retro style fridge (original not modern repro) Are there companies that do this? Has anyone any ideas? Many thanks. Susie
    #131549
    Re: Reconditoning a 50’s fridge
    Interesting idea. The mechanics of the old ones are pretty straight forward and wouldn’t represent a technical problem to an engineer. Any trim or manufacturer specific component would most likely prove a struggle after this length of time.
    One other thing to bear in mind is the vastly improved efficiency of modern appliances – the insulation back then wasn’t all that good.
    If you check in the Directories section or Repairs@ you should be able to make contact with fridge engineers local to you.
    This is interesting:
    http://hem.dis.anl.gov/eehem/01/010705.html
