recumbent washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum recumbent washing machine
  • #42333
    lordswood
    Can anyone tell me if it’s OK to lay a washing mahine (carefully) on it’s side or back to effect a repair. I am unable to kneel on the floor due to a dodgy knee and my sight’s not what it was.
    #273151
    kladave
    Re: recumbent washing machine
    Providing it’s on the soap dispenser side it will be ok
    What do need to repair on the machine??
    #273152
    lordswood
    I’m replacing the carbon brushes – again. Why the soap dispenser side?
    #273153
    Washman
    So that the water cannot get onto the electronics.
    Washman
    #273154
    Exactly what make of machine do you have. Certain machines can be laid backwards to replace brushes if you lower them down gently.
    lordswood
    It’s a Bosch WFL2450 Maxx. I managed last time just by tilting it, but I’m older and creakier now.
    #273156
    Not the easiest of brushes to change in situ TBH, I would advise removing the motor completely.
    I’m 61 and my old knees have suffered from 20 years of football and thirty years of squash ( and still playing 🙂 ) but I still manage.
    If it has the small teardrop shaped back panel then if you tilt the machine forwards against a wall and use a small socket and ratchet it is quite easy to remove the motor, just prise it off the drum mountings.
    If it has the large full size back then motor removal is a doddle.
