Red light to Start/Pause touchpad and no heat
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Red light to Start/Pause touchpad and no heat
  • #100165
    gordondrysdale
    I have a Zanussi Lindo 300 tumble drier. The Start/Pause touchpad light illuminates red during a cycle and the machine is not providing any heat to the drum. Does anyone know what this fault is and how I repair it? The filter and condenser are both clean and the machine drains to an external drain.
    Gordon
    #479540
    with a lot of faults the light flashes in a sequence
    does yours flash and if so count the flashes. it should do a number of flashes then a short break and repeat
    gordondrysdale
    Hi Dave, thanks for your post. the light doesn’t flash, it is constant. Gordon
    #479542
    to look anything up will need full model and pnc number
    gordondrysdale
    Hi Dave,
    The model number is ZDC8202P.
    Type TC09H65HW.
    Product No 916 097 379 00.
    Thanks so much.
    Gordon
    #479544
    manual does say light should flash on fault detection
    suggest you look at heater first. check the stats and element continuity
    gordondrysdale
    Thank you.
